Baumatic B180 Oven
  • #23144
    Housewife
    Similar problems to a lot of the webbers here. My fan oven has stopped working. The fan still turns, but there is no heat. The grill still works ok though. Have checked that I am on the correct setting and not on fan defrost.
    Any ideas, or things I can do to check? Cheers.
    #197129
    msappliance
    Re: Baumatic B180 Oven
    Hello housewife,
    sounds like the heating element is faulty you carnt really do any checks unless you start to strip the cooker. If you do disconnect power first.
    #197130
    Almost certainly a fan oven element failure. You can remove the rear inner panel of the oven to view it. This is most informative:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=103
    If you feel competent, spares@ukwhitegoods.co.uk will be able to supply a replacement for you at a good price and quickly. If you’re not sure, use the link below for a UKW engineer in your area.
    Stay safe, power off at all times if investigating.
    Housewife
    Thank you for your suggestions. I check it out, there are no engineers in my area (Scottish Borders) so it might be a bit of DIY.
