have just changed heating element and drain pump on the above
did have leak on drain pump which activated flood drain on first start up
cleared leak, dried out base plate
now unit is starting with drain, then fills and instantly drains as if float switch as been activated, it does this twice
and the goes into fault mode, light 7 flashing glass symbol and buzzer sounding
have checked float micro switch …closed circuit ..open circuit when activated
as this is my own appliance got my head scratching mode on
any help appreciated
graham
leicestershire
