Baumatic BDI631 – high pitch (almost screaming noise) during wash cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Baumatic BDI631 – high pitch (almost screaming noise) during wash cycle
  • #98322
    emohawk11
    During the wash cycle, the dishwasher is making quite a high pitch noise. It’s never done this before so I’m not sure whether to be concerned or not.
    The dishwasher is heating the water OK, rinsing OK, and draining fine. The noise only occurs during the wash cycle i.e. when the rotar arms are moving.
    Any thoughts on what the loud noise could be and what I can check ? I replaced the drain pump about 3 months, a broken cable 6 months ago, so I know my way around the dishwasher a little.
    #471833
    well it has to be something thats moving
    as it starts to make the noise try jamming each bar in turn to see if it stops. if no I would suspect the wash motor
    emohawk11
    Removed both water rotar arms, and the noise persists the second the wash cycle / water gets pumped. I suspect as you say, it could be the wash motor. Looks relatively straight forward to replace ? only downside is it looks a little on the pricey side.
    #471835
    it seems to be a pump used on a few different models and yes Baumatic are known for silly prices
    suggest you ask site shop if they can source at a better price
    emohawk11
    Thanks Dave – it’s also occured to me, maybe just put up with the noise till it packs in – might get days, weeks, months, years. who knows??!
    #471837
    emohawk11
    Just a thought, If its the motor bearing and it wears more, is the motor likely to leak water ?
    #471838
    could be leaking that made the bearings go
