Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Baumatic BDI631 Thermostat
- This topic has 10 replies, 3 voices, and was last updated 10 years, 4 months ago by
rothie.
November 18, 2015 at 7:56 pm #86733
rothie
ParticipantHi
Could anyone tell me where the thermostat is on this machine. I have looked at the replacement ones on sites but cant see anything like this under the machine.
November 18, 2015 at 8:19 pm #432885admin
KeymasterRe: Baumatic BDI631 Thermostat
It’s in the base BUT what is the actual fault you have ?
Bryan
November 18, 2015 at 8:36 pm #432886rothie
ParticipantRe: Baumatic BDI631 Thermostat
The fault is the dishwasher is not heating the water, I have tested the heater and it is ok, so was looking for the thermostat.Thanks
GraemeNovember 18, 2015 at 8:41 pm #432887admin
Put it on a wash then after it has filled with water pour another 3/4 ltr into it and then close the door and see if it heats up then.
Bryan
November 18, 2015 at 10:50 pm #432888rothie
Thanks for that Bryan, tried it but no change. sorry for the late reply I couldn’t access the site.Graeme
November 18, 2015 at 11:57 pm #432889admin
Hi.
Then it will be the one shot stat in the base. If you look at the back whilst it is washing the water should be pumped up the rear tube. If it’s not then it may be the diverted flap on the side of the motor which can be removed if you don’t want or use the 1/2 load option.
You won’t easily see the button stat if you don’t remove the rear panel and base panel..But remember… Unplug it !!
Bryan
November 19, 2015 at 10:51 am #432890rothie
Hi Bryan
Thanks for that
I Have removed the base again but still can’t see anything that looks like the ones offered for sale. There is a small bullet shaped sensor on the outlet held in by 2 small screws.Graeme
November 19, 2015 at 8:17 pm #432891rothie
Could this be a temp transmitter / thermistor?Thanks
November 19, 2015 at 8:25 pm #432892admin
I’m not in front of it so can’t see what you see. The cut out is normally screwed into the base or on the back cross member. also if there is not enough pressure going through the pipework from the motor through a black rubber hose with a microswitch attached then goes unto the top spray arm..
Bryan
November 19, 2015 at 9:15 pm #432893rothie
Hi Bryan
I have attached a pic of the probe, have you any idea if this could be it?
GraemeApril 3, 2016 at 11:19 am #432894bullettooth_toby
Hi Graeme,
Did you ever get this resolved as I have the exact same problem?
I purchased the official replacement before even opening the machine as I was confident it was a thermostat issue. However, the part that I bought looks is the blue one in the picture, but like you, the only thing I can find that looks like it could be the thermostat is the other one which is identical to what you pictured.
Can you help me out at all with how you got this sorted?
