Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Baumatic BDIN 1L38B not working – three lights
- This topic has 7 replies, 4 voices, and was last updated 3 years, 8 months ago by
turnyourtvoff.
July 11, 2022 at 7:20 am #100994
turnyourtvoff
ParticipantHi,
A Baumatic BDIN 1L38B dishwasher purchased in October 2020 has stopped working.
The machine is not responding to any commands except for off and on commands and three lights flash when any button is pressed, the 3h, 6h and 9h lights.
It has been turned off and on at the mains and the problem persists.
Does anyone have any suggestions on how to troubleshoot this please?
Thank you
July 11, 2022 at 9:22 am #482948electrofix
Moderatorthe light flash but is there a sequence to it like 3 flashes then a pause and then repeat
if yes its a fault code
another idea is the pic belowDave
July 11, 2022 at 7:45 pm #482949electrofix
Moderatoris the door opening and closing properly
could be the door lock is in the closed position but the door is open. A lot of dishwashers are not able to select a programme in this condition
July 12, 2022 at 10:17 am #482950turnyourtvoff
ParticipantThe door appears to be opening and closely with no problem.
I have not been able to find anything conclusive online apart from the following suggestions:
– flashing lights indicate that the water inlet tap is turned off
– this thread: https://www.justanswer.co.uk/appliance/e4j7b-baumatic-bdin1l38b-bk-built-dishwasher-need.html – focusing on salt and rinse aid or a leak meaning water got into the bottom of the unit – suggestion to tilt the machine
– this thread https://www.justanswer.co.uk/appliance/gv5e3-baumatic-bdin1l38b-bk-built-dishwasher-need.html this thread focusing on leak/seapage and the leak float – suggestion to drain machine and/or clean with boiling waterI also called the customer service but they were not willing to share any information on the phone and wanted me to book and pay for a technician visit
Thank you
July 12, 2022 at 8:38 pm #482951electrofix
Moderatori would still check the door lock and switch are operating as expected
April 5, 2023 at 3:24 pm #482952Woj101
ParticipantHi [USER=”57991″]turnyourtvoff[/USER] – just wondering how you resolved your dishwasher issue. I seem to have the exact same issue with the same model dishwasher, bought May 2020.
Be grateful if you could let me know whether you managed to resolve the fault, got a repair done, or just replaced the p.o.s.
Thank you.
April 13, 2023 at 8:12 pm #482953Woj101
Participantturnyourtvoff wrote:Hi,
Thank you
Just bumping on the chance that OP or anyone else can share any ideas of a solution to this issue. Thanks.
March 11, 2024 at 2:36 pm #482954subs
ParticipantJust had one of these with exact same problem. After lots of trial and error managed to clear it by holding express button and clock symbol at the same time for a few seconds. So guess it was child lock. Hate these rubbish dishwashers. Doesn’t even have an anti flood device. Just corrugated plastic cover on base like the Hoover washing machines.
