Baumatic BDIN1L38B-80 60Cm Integrated Dishwasher Door Panel Fixing
Home Forums Public Support Forums General Enquiries And Questions Baumatic BDIN1L38B-80 60Cm Integrated Dishwasher Door Panel Fixing
  • #98552
    turnyourtvoff
    Does anyone have any tips please on how to fit a door panel to the Baumatic BDIN1L38B-80 60Cm Integrated Dishwasher?
    I have looked online and there are a lot of videos and info on other models but I have not found any for this model or any templates.
    This is the best picture I could get of the front for now.
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://attachment.outlook.live.net/owa/MSA{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3Aali_Gil{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}40hotmail.com/service.svc/s/GetAttachmentThumbnail?id=AQMkADAwATY3ZmYAZS05MDU5LTg2ZDQtMDACLTAwCgBGAAAD1BCaIkRdmkugfVEqyFEShAcA{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2BRtKzBO180q8y9kY5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2FIf9wAAAgEMAAAA{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2BRtKzBO180q8y9kY5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2FIf9wAE2nqMcAAAAAESABAAbj1NIK5UlU2qJbuS{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2BCTfSQ{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3D{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3D&thumbnailType=2&owa=outlook.live.com&scriptVer=20201024001.02&isc=1&X-OWA-CANARY=F35w2nFLuEG5bJpBkMOp_1CYdSGHe9gY1u5kKsFN1IBsomIsOq2DMHF3SvrPGRwpspzCkCS9Ngs.&token=eyJhbGciOiJSUzI1NiIsImtpZCI6IjU2MzU4ODUyMzRCOTI1MkRERTAwNTc2NkQ5RDlGMjc2NTY1RjYzRTIiLCJ0eXAiOiJKV1QiLCJ4NXQiOiJWaldJVWpTNUpTM2VBRmRtMmRueWRsWmZZLUkifQ.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.dthLBQbje0cx2ABf0ZN9T9UqGrozL1ZY8ugdtjefPoALb1YejDVy41x3iAAbMWBiedP__c80I6mNNKtZajsdwRZaVglz-tXRGjmFlUcg3paWJSUtS-VOr80mCoTUUDB7X05JuZ2X5ixZgaCk6KIzOlC46KRiebgcVLZ9QrOkil1Bsomn89bHYKCyO1QDHZG1Q6NoycfpIFELzqgRa0sEXGfvcsNFyo92ScJYDcudQxtVpxLQVlAKICfPGS3VIGxHDwnT6A0-EaSo1Sa_7TVhSoLSdMmQweAeqxya5JNkumqdZwvU2XccuKNix668EBXE0nTZqQVyexFw-spCejE0Rg&animation=true”}[/IMG2]
    I will also need to fix the plinth.
    Any tips will be much appreciated.
    #472807
    manual shows this
    turnyourtvoff
    Hi [USER=”4209″]electrofix[/USER] – thank you very much. Can you please send me that manual. I may be looking at the wrong one.
    #472809
    let me have an email add and will see if i can find it again
    turnyourtvoff
    Thank you – I have sent you a private message with my email address.
    #472811
    turnyourtvoff
    Two more questions please.
    a) do you need to use a drill to fix the screws to the cosmetic door panel or could I attempt to screw them in carefully?
    b) do you know how to adjust the tension on the door?
    Thank you
    #472812
    you normally drill a small pilot hole then screw into that
    I dont normally bother as with care the screws go in no problem
    if you have not got the original screws make sure they are not too long otherwise they will go through to the outside
    dave
    #472813
    turnyourtvoff
    Thank you – I have the original brackets and screws just waiting for the panel and plinth.
    The kick plate/plinth is quite recessed are there any tips on attaching the plinth so it won’t be so sunken?
    The dishwasher is integrated but the door panel and plinth are not going to match the kitchen so its not going to be a flush run. It’s an old kitchen so we had to assume the contrast and get an individual door and matching plinth that I will need to cut to size for the appliance.
    #472814
    none as i seldom attach the plinth
    you inly need to when the plinth is only as wide as the dishwasher
