I ordered a control board for this machine from CDSL and am not sure if I have the correct one. CDSL list two different boards depending on serial number but when you order the older board ( part number 672050300060 ) the website changes to the newer one ( part number 672050300196 ) The newer board is listed for appliances from serial 070306533, the serial on my machine is 070157072.
The problem is that there are two plugs and three single wires that could be put on the wrong position on the replacement board as the layout is different.
Have I got the correct part and if so has anyone got any info on where to put the wires on the new board??
John
