Baumatic bdw13 e3
  • #45166
    talcy69
    Dishwasher is baumatic bdw13
    Right i hope someone can help, dishwasher keeps giving e3 error, got no power to the element, no power to the 2 thermostat cutouts, can anyone give me some pointers does the pcb control power to the element.
    What gets me even more is its only 13months old and baumatic wants me to pay £85 + vat call out, tech support are less than useless, know my way around citcuits, so if you can help please.
    Thanks in advance.
    #283878
    Specialist01269
    Re: Baumatic bdw13 e3
    Hi: Baumatic are not a brand I often see but error E3 is shown as NTC or Element failure but could also just as well be a wiring fault, so the first thing to do is obviously trace the wiring back to the Control PCB & check for continuity.
    As for the PCB as far as I know it controls everything.
    HTH: Andy
    #283879
    spimps
    Whilst you have the door off to check wiring remove control PCB and check printed circuit for a blackened solder area which could be the heater relay,it can be re soldered if that is the problem.
    BG
    #283880
    Specialist01269
    spimps wrote:Whilst you have the door off to check wiring remove control PCB and check printed circuit for a blackened solder area which could be the heater relay,it can be re soldered if that is the problem.
    BG
    Thanks mate: I forgot about that, think I must be getting too old for this 😆
    Andy.
    #283881
    spimps
    Specialist01269 wrote:
    BG
    Andy.
    Are you older than me ? come the olympic year I”ll be free 😀 😀
    #283882
    talcy69
    Cheers guys for the replys, checked wiring all good, had a look at the pcb, and found the heater relay, and you were indeed corect, replaced the relay and its now heating again.
    thanks for taking the time to reply, it was going down the tip this weekend if i didnt sort it.
