Baumatic bdw15 E4 error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Baumatic bdw15 E4 error
  • #42273
    snoged
    urgent help needed please 😥
    i have a Baumatic BDW15 that once started after a few minutes beeps and shows a E4 error and stops.
    there is no water at the bottom of the machine and the polystrene float is not stuck and the tip switch seems to be working the drain hose is fine and the inlet has not been changed.
    machine was working fine until salt,rinse aid and 3 in 1 tablets where used.i imagine that this combination has caused the problem.
    any help would be very much appriciated.
    #272918
    snoged
    Re: Baumatic bdw15 E4 error
    looks like i better save up and buy a Miele !!
    #272919
    From the Chinglish:
    “Any time the micro switch has acted for 2 seconds, the dishwasher will shut off all theloads and drain
    for thirty seconds, the alarm buzzer will ring for thirty seconds and the windows display E4 . If the
    micro switch resets during the draining time, the dishwasher will work normally again, other wise the
    dishwasher will keep draining until the micro switch resets.”
    snoged
    hi
    thanks for the reply,but not don’t quite understand.
    how do i get the m/switch to reset during draining ?
    thanks
    phil
    #272921
    helo_75
    pull it out, tip it to one side, wait till the water stops and thats it
    if it keeps reoccuiring, youve got a leak
    #272922
    snoged
    hi
    thanks but you say tip to one side till the water stops ?but what ater there is none at the bottom of the machine….or will the machine just drain ? if so where would the leak be ?
    sorry but not too sure what you mean.
    thanks
    phil
    #272923
    You state that there is no water in the tray under the machine. Therefore, the float switch cannot be activated and the machine is lying to you. In this case, check that the heater cut out (black blob screwed to underside of the tank) is showing continuity. If it is, check the heater for resistance (25-30 ohms is acceptable). If that’s in tolerance, the pcb has probably thrown a wobbly and the damn thing wants chucking in a skip.
    Power off first, please.
    snoged
    lol penguin45 your’e probley right !ill be dammed if im going to check ohms & blob screws !
    because i have had just about enough of this bloody chineese crap …..anyone want it for spares ?
    im going internet shopping tomorrow….any reliable recomendations are more than welcome !
