Either faulty harness, regeneration unit or pcb, at the end of program the solenoid valve on the regen unit opens for a short time and flushes saline solution through the bead chamber to de calcify it, so need to check valve and the continuity of its harness back to pcb, if they are both ok then pcb not putting supply to unit
