Baumatic BDW5 problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Baumatic BDW5 problem
  • #23488
    tmo
    i have as per the title a Baumatic BDW5, had it three years not a problem and then ….
    basicall it doesnt appreat to fill, if you put the machine on to a rinse it will start, drain the old water down. at this point it should engage the spray bars and give it a good old rinse, instead it trickles about half an inch of water in and stops. the lower and uper spray bars arn’t even moving ??
    any idea’s
    cheers
    #198293
    Re: Baumatic BDW5 problem
    Sounds more like the circulation motor is not running. When the 1/2″ of water is in, can you hear a faint humming noise?
    tmo
    Penguin45 wrote:Sounds more like the circulation motor is not running. When the 1/2″ of water is in, can you hear a faint humming noise?
    no it turns its self off,
    basically drains for about 1 min, fill for 1 min then stops !
