baumatic bfd60ss dishwasher
  • #14283
    den
    switch on and all leds lit, beeping. nothing else happening.
    There was water in the base. When this was emptied, programmes were selecting, but just beeping when start button pushed.
    As usual the stupidly situated motor was wet.
    Ordered motor. Then tried again before leaving. It actually started this time but prog light was flashing. Dont know if this is normal. Left customer to try it.
    Any suggestions lads, and also, does anyone know the reset procedure for these (if any).
    Thank you for any replies guys.
    #158886
    TOWAN
    Re: baumatic bfd60ss dishwasher
    was a baumatic service engineer for 4 years and know this model well.
    if you remove water from base a leave to dry the m/c may well spring back into life!
    if not a new pcb will be needed.
    also why was the base full of water?
    there have been a number of mods for this range to stop this happening.
    #158887
    Tom
    I’ve encountered this model today. Stopped with water in the machine; refused to empty. Found a small piece of glass in the drain pump but still wont empty.
    The On/off button switches the machine on; selecting any program is allowed but immediately after the start button is pressed the first (leftmost) of program leds flashes continuously as well as beeping. Beeping for 10 beeps but led flashes for ever; the beeping starts again for 10 more after a time.
    No water in the base. The user manual says switching off and on again cancels the program.
    Hope Towan sees this.
    Any help/suggestions welcome
    tom
    #158888
    Haier – Chinese Indesit copy. Should be door lock fault; usually means that the board has failed in some way. Do you really want to put your customer through this?
