Baumatic BFW1201W
  • #53583
    nigegt
    Baumatic auto washer (looks same as amica and ise) comes up e22 any ideas
    Nige
    #316531
    gandh1
    Re: Baumatic BFW1201W
    might be worth checkign that model no. might be a bfw1210w
    the 1210s are the amica lookalikes. not worked on one so cant say if they are or share the electronics at all but this is the info on here relating to e22 for amicas. i have been out to a handful of amicas that did e22 for unbalanced loads, and in one occasion the 3rd time it did it it was actually the pcb. but this was cos the solenoid had a constant slow leak and dripped on the drum and then onto the motor. i note the motors seem to be pretty exposed (no cellophane covers like on bosch/hp)
    “E22 Motor triac shorted – there is a signal from the rate generator even
    though no power is supplied to the motor
    The E22 error code is displayed and the wash programme is terminated.
    Faulty electronic circuits (the error may occasionally be caused by a heavily unbalanced load such as a blanket or dressing gown) “
    from here:
    http://www.ukwhitegoods.co.uk/modules.p … 0&start=90
