Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Baumatic BL890 electric lower oven no power.
- This topic has 22 replies, 3 voices, and was last updated 5 years, 5 months ago by
phantomrip.
October 31, 2020 at 6:12 pm #472845
phantomrip
ParticipantI can’t upload a photo, i get a message advising the file is too big, could I email one to you?
November 1, 2020 at 9:11 am #472846tubafan
Participantphantomrip wrote:I can’t upload a photo, i get a message advising the file is too big, could I email one to you?
It’d be better to use a photo sharing site – eg Flickr (many others exist) then all forum members will be able to see it.
🙂November 1, 2020 at 9:41 am #472847electrofix
ModeratorAs tubafan says use an external site google pic or the like then most of these sites give you the option to post a public link so we can see it
November 2, 2020 at 12:29 am #472848electrofix
Moderatornow you need to check as i cant be in any way certain this is correct
look at the switch, the number of positions and the cam postions
then ask if they can be certain its correcti have no way of checking it just seems to look correct
https://www.4baumatic.co.uk/cooker-o…elector+switch
when you put model into site it comes up with
DaveNovember 11, 2020 at 6:49 pm #472849phantomrip
ParticipantToday my new switch arrived, great I thought, it was a like for like, carefully removed it ensuring all of the terminals were fitted in the correct position, tested the lower oven and it worked, great I thought, cooking tea and noticed that the with the temperature switch set at 150 the light that indicates the temperature has been reached never went out, the oven is getting very hot though. Any advice appreciated although I think it may be something may have been affected when the selector switch burnt out.
November 11, 2020 at 7:40 pm #472850electrofix
Moderatorwell you either have a wiring error or the stat is faulty
if you turn the stat you should hear it clicking as the contacts close and open
November 11, 2020 at 8:17 pm #472851phantomrip
ParticipantThe stat only clicks at around the 50 mark on the switch after the oven has been turned on for approx 10 minutes, it doesn’t click at all at room temp (oven cold) unlike the top oven stat that clicks at room temp
November 11, 2020 at 8:22 pm #472852electrofix
Moderatorsomtimes they dont click at room temp
set stat to 50 degrees or so
turn oven on
is light on with stat at zero ?
