Baumatic BL890 electric lower oven no power.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Baumatic BL890 electric lower oven no power.
Viewing 15 posts - 1 through 15 (of 23 total)
  • #98556
    phantomrip
    Was working fine last night. The Smaller top oven and grill works fine. I have turned off the power and reset the oven clock to hopefully rule out timer.when I turn the power knob for lower oven, the green light does not illuminate on any of the settings The fan does not operate and the internal lights don’t illuminate, the red light alongside the temperature knob flickers occasionally when turning the power knob between settings. Any help or advise would be appreciated.
    #472831
    are you sure that model no is correct as i cant find it
    phantomrip
    Apologies, it is a BOD890SS
    #472833
    well it has very poor diagrams and since it has chinese writing on the circuit it looks to be chinese built
    probably going to be one of 2 things
    1 timer it could still be a relay failure in the timer stopping power
    2 multi bank switch that contols the oven
    as for part nos am stuck as none are listed. if you need any we just have to hope candy ( now Haier) can supply them as they bought Baumatic out
    phantomrip
    Thanks Dave, my first thought was the switch , as I turn it slowly between the various settings the red LED which is normally lit until the selected temperature is reached flickers dimly.
    #472835
    take the top off after turning off and inspect contacts for signs of burning or damage
    phantomrip
    Thanks Dave, I’ll take a look at the weekend
    #472837
    phantomrip
    Hi Dave, I have removed the oven top today to look at the switch, there are signs of burning around pin / connector P8, I’ve taken a few pictures of the switch but having looked online for a replacement the numbers etched into the plastic don’t seem to match anything I find online, any advice appreciated.
    #472838
    phantomrip
    Model BOD890 SS
    serial number 3370135316040035
    etched on top of switch
    FD 103M
    AC 250V 16A
    T1 50 5E 4
    pins are numbered 1 to 8 & P1 to P8
    #472839
    tubafan
    tubafan
    am hitting brick walls as well. looking at the only tech available i have a breakdown diagram but no part numbers listed at all
    since the Gias group took some spares are not available
    you need to talk to Baumatic spares Spares Telephone: +44 (0)844 692 3606
    you could also message the site shop as a long shot in case they have more info than i have
    phantomrip
    Tubafan, thanks for your help, although the numbers seem to match my connections are 1 to 8 and P1 to P8.
    #472843
    phantomrip
    How do I upload a photo of my switch?
    #472844
    tubafan
    phantomrip wrote:Tubafan, thanks for your help, although the numbers seem to match my connections are 1 to 8 and P1 to P8.
    Sorry about that – I think we need a photo then to help identify it.
