Baumatic BO910SS Hinge replacement
Home Forums Public Support Forums General Enquiries And Questions Baumatic BO910SS Hinge replacement
  • #101514
    simon p
    Does anyone know how to remove the hinges on this type of oven – see attached video / photos – I have the door off and have removed the two screws at the bottom of the door that hold the hinge but the top of the hinge is held in place by a fold of steel – seems like the hinge was never meant to be replaced – am about to give up and throw away the oven and buy a new one because the hinge wont come out
    #485040
    think its just a clip and hinge slides out
    cant see pic probably because they are too big
    host them elsewhere and post public link
    simon p
    here is a link to a video https://streamable.com/625svu
    #485042
    simon p
    ok i see
    the hinges are in the locked postion. they have to be unlocked to get them out
    put the screws back
    grab hinges frimly with pliers and pull to allow you to release the lock
    then care fully let the hinge go to the closed postion till you can let go
    undo screws again and you should be able to get the hinge out
    simon p
    Dave – thanks so much worked perfectly – I have swapped the hinge from the bottom oven with the top – its a temporary solution as clearly the top oven springs are stiffer – you can tell from the number on the hinge 10 v’s 3 – so will try and source some new ones for the top oven
    #485045
    as far as i can see hinges no longer available both main and small oven
    should be part nos X1260000096 or 7002461 for main oven
    small oven is X1260000239 or 7006943
    you could message the site shop but cant see stock anywhere
    simon p
    I was lead to believe that the part was 1260000095 – and the site says they have some – but very rare – I’m taking a risk ordering 2 for GBP 65 as I could buy a brand new double oven for GBP 250
    #485047
    yes found a site that seems to say they will fit but cant confirm
    [USER=”2″]kwatt[/USER]
    K can you confirm
    https://shop.ukwhitegoods.co.uk/1260000095-oven-door-hinge
    will fit this oven and the availabilty status
    simon p
    Thanks Dave
    My view here is that the BO910SS was/ is a good oven and save for the hinges performs well – always preffer to repair rather than replace with new – same approach with cars which is why we run a 1956 Landrover and a 1965 Ferrari
    #485049
    can go with the repairing theme we as engineers will always agree with but comparing the oven with the cars no
    cant see the oven lasting over 50 years at least not modern designs
    That hinge is available, ordered as needed now as it’s not a commonly used one and I think set to go obsolete.
