Baumatic BT243OSS Range Cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Baumatic BT243OSS Range Cooker
  • #60847
    jontymox
    Good afternoon all,
    Wondering if someone can advise on a fault on the above oven.
    The main fan oven is really inefficient; i.e. takes far too long to heat up, and will not reach maximum temperature.
    I have tested the circular element, which gives a very high resistance, and appears in good order.
    So, I renewed the thermostat assembly, which has improved the speed the oven heats up at, but still does not reach maximum temp.
    Is there a separate control unit/module that I am unaware of, or should I renew the element?
    I have also checked the element when operational, and it does not get red hot.
    Any advice appreciated.
    jontymox
    #343867
    chezza
    Re: Baumatic BT243OSS Range Cooker
    is there an element under the oven floor ?
    has the shelves or base been coated in foil ?
    Does the setting use the upper element as well as the circular one ?
    #343868
    jontymox
    Hello chezza,
    Yes, there is an element under the oven floor, although I don’t know if it, or the upper element is used in conjunction with the circular fan oven element.
    Also not sure of upper and lower element condition, as I didn’t test them due to circular element not getting red hot.
    Shelves or base not coated in foil.
    jontymox
