Re: Baumatic BT2760SS Base element
im sure i have posted this up before but cannot find it, open the pan storage draw, look up thats the plate that needs to dropped at the front, to do this remove the rear back panel and there will be 2 screws that hold the rear of that plate up, remove screws and drop the rear of the plate down, it will now slide back 5mm and drop off the front support ridge, remove element retaining screws and reverse procedure. hope that makes sense.
Bob.
