Baumatic BT2790 switch fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Baumatic BT2790 switch fault
Viewing 1 post (of 1 total)
  • #21698
    drinky_2003
    I have a 4 year old Baumatic double oven, BT2790. The main oven has stopped functioning and on inspection I have found the terminals on the multi-position switch to be badly overheated. The wires are locally brittle and at least one wire has come away from its connector.
    Has anybody else had this fault and discovered the cause? The oven fan and elements appear to work ok but the fault was the switch.
    Cheers,
    Drinky
