Baumatic BT3500SS Fan Element?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Baumatic BT3500SS Fan Element?
  • #27227
    nasman
    My 3yr old baumatic dual fuel range cooker decided to prove me wrong only a few hours of commenting how it worked without problems…
    The fan oven function is not giving any heat despite the fan working – all other functions seem ok – I opened up the back panel inside the oven and felt a rough area round back-top of the ring lement, does this means the element has gone?
    The guarantee form was never sent back to baumatic so I’m guessing I won’t be covered under their 5yr parts guarantee… If I attempt the job myself (will probably have to take the external back cover off too), is there a part I can order from here? Or how much would one of the engineers in the Luton area generally charge for a fan element repair?
    Thanks for any help.
    #213144
    Re: Baumatic BT3500SS Fan Element?
    This:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=354
    fits most Baumatics.
    If you’re not sure, type your post code into the repairs@ link below to find a UKW approved engineer is your area.
    Power off if you intend to proceed with the repair yourself.
