Baumatic BT80GL
  • #40241
    actd1109
    Both lamps failed in quick succession, the second one taking out a 5A fuse in switch spur. Replaced the lamps & fuse, fan motor works fine but still no light. Does this mean the pcb box where the lampholder cables disappear has failed? If so any suggestions on where to get a replacement for sensible money? Many thanks in advance.
    #265231
    Re: Baumatic BT80GL
    PCB is p/no F88.7.280.330. Probably only available from Baumatic. Good luck – they’re not the easiest firm to buy parts from.
    actd1109
    Re: Baumatic BT80GL
    Many thanks Penguin45 – I didn’t expect a reply on a saturday evening!!!!!!
