Baumatic BT904 built in double oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Baumatic BT904 built in double oven
Viewing 5 posts - 31 through 35 (of 35 total)
  • #123265
    Dazman
    Re: Baumatic BT904 built in double oven
    Dave,
    Not yet. Could you send another one and then I will return one of them if they do arrive?
    Daryl
    #123266
    Dave_Conway
    Will do 🙂
    #123267
    Dazman
    Dave,
    The safety state I got from you worked for a while but it has burned out now also. What would cause this part to get VERY hot like a short. It has blown out the low amperage one I got from RS and now the correct part that you supplied. It heats up of it’s own accord. Any ideas appreciated. I am going to order a couple more hoefully they will arrive this time. The last two never did, but the one replacement you sent did. Thank you. Daryl (It is the Delonghi ESS903 pro)
    #123268
    Dave_Conway
    I would say it’s either loose terminal connections on the thermostat or a cooling fan issue causing this to cut out quite frequently 😕
    There is evidently an underlying issue causing premature failure I would think.
    #123269
    clemwo
    Re: Campini Ty60 85°C Thermostats
    Campini only sell through wholesalers and gave me ‘Micromic’ in Italy as a contact. I’ve arranged an account and ordered a pack of 85°C Thermostats. When they arrive I’ll offer the spares to whoever.
    They have quite a few different temperature stats in their catalogue but as they all look the same they’ve used a standard photo – for a 30°C device – so I couldn’t check the code stamped on the metal surface of the one I’ve ordered.
    Never mind, it’ll fit and function OK.
