Baumatic Bwd 12.1 F4 Fault
  • #54886
    A1engineer
    hi guys, had 1 of these today showing F4 fault which relates to a door fault, i replaced the interlock but F4 remains i checked pcb no obvious signs of problems, really left sctraching my head 😳
    if anyone can help or has a test program or manual for this id really appreicate it, promised id go back on Tuesday 🙁
    #321303
    funkyboogy
    Re: Baumatic Bwd 12.1 F4 Fault
    dont know if this is helpfull or not , but if apliance looks like merloni
    fault code relates to flow meter ??
    ally
    #321304
    A1engineer
    not really like a merloni at all ally, looks just like the caple intergrated machines white knob in centre blue screen etc machine doesnt do anything you select program press start it pauses then displays f4 which according to user manual means door is open!!!, had a few before which needed a door lock but tried that with no joy…………
    #321305
    funkyboogy
    no probs i have a couple of service manuals , but not for the model you have … one for merloni looking think and the other for haire built one ?
    dont know anyone else ..
    ally
    #321306
    ANDYVIVO
    Sounds like a Fagor, if that helps? Andy
    #321307
    funkyboogy
    looked at fagor fault code … e3 = check heater tunnel and door safety device …
    poss heater fault …if you have changed door lock
    ally
    #321308
    bigchrisoioi
    its baumatic!!…burn it !
