baumatic bwd12-1
  • #61585
    robbo1973
    Hi all I have one of these machine swhich will fill fine and tumbel but after a few mins clockwise remains fine but anti and it tumbles mega fast then cuts out for a min then repeats,It does sound like a pcb problem but has anyone had anything siomilair?
    Has anyone a part number for main pcb it is made by fagor so dont know if will be cheaper getting from there part no.
    cheers chris
    #346724
    gandh1
    Re: baumatic bwd12-1
    chris, be aware just cos its a fagor built machine, the electronics might not be the same. using source manufacturers parts are fine if its a static component – door handles, tubs, knobs etc but unless you can cross reference part descriptions adequately its not worth the risk. it is unlikely as baumatic are a brand rather than a manufacturer, but fagor may have been requested to modify parts of wash cycles for faster length, lower fill levels etc which will obviously stuff up expected readings for p/switches etc so even tho the board will be the same to look at, the software could be different…
