Baumatic dishwasher error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Baumatic dishwasher error code
  • #53319
    Ally
    Sorry if this is in another thread but i failed to find any info on search.
    The machine pumps out takes in water to the correct level starts to heat the water and after approx 7 mins starts to beep. On opening the door the four leds are flashing alternately first the second led from the left then the first third and fourth flash.
    #315386
    Re: Baumatic dishwasher error code
    Model number?
    #315387
    Ally
    Sorry for the delay iv’e been off sick with the flu. She said it was the cold but that is women for you.
    Model No DW-24eI
    #315388
    No, it isn’t. All Baumatics will start BDW—.
    Ally
    Sorry BHD5 sounds abut right must be the old age.
    Ally
    #315390
    There’s a BDW5, which is a Fagor. Lights 1, 3 + 4 are listed s a control unit failure.
    Ally
    Thanks for that Chris. Had a sneaky feeling it was the control board but not worked on this model before I wanted to check. I have virtually checked every other part on the machine, and insulation etc.
    Thanks again
    Ally
    #315392
    DDDave
    I have this same fault with a BDW5 at the moment. A search found this http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=3&t=17250
