baumatic dishwasher lower spray arm not turning
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries baumatic dishwasher lower spray arm not turning
  • #40487
    zem
    hello chaps i wonder if anyone has the awnser to a lower spray arm not turning on a baumatic bfd60ss,water level is fine no blockages evident on arms or pipework,i blocked flow to top spray arm but still did not get movement on the bottom.. thanks for your help…
    #266465
    Re: baumatic dishwasher lower spray arm not turning
    Diverter valve jammed or failed. If no supply to valve, PCB.
    agree with the penguin
    i usually remove the plastic flap that causes it if i remember correct this dishwasher has a half load facility that turn off the bottom deck
    valve cover only 4 screws remove flap and replace most customers will be happy with that they never use half load anyway
    zem
    thanks for the advice where is the flap located ???cheers chris
    #266468
    sorry for delay in reply
    flap is just below bottom arm if you look in bottom of dishwasher where pump motor is you will see just before tube goes through the tank floor to go to the bottom arm a coil and a square plate held on with 4 screws
    hope this helps
    dave
