Baumatic DW Over Fill
  • #50868
    subs
    BDW15. Customer said machine displaying E4 over fill.
    Found flooded base and drained and restarted but found no leaks.
    What would cause it to over fill? Inlet flow meter ok.
    Subs
    #306195
    lee8
    Re: Baumatic DW Over Fill
    Baumatic have issues with E4, they`ve changed several things, none much success.
    I can`t remember if that model has the two over fill hoses that run into the base.
    There in the corners just at the front and you`ll notice two grey pipes feeding into the base.
    The idea is that if the machine overfills the water enters the base and stops functions.
    Soap powders cause this too happen in normal working conditions, so they removed these hoses and fitted extra pressure switch, that still makes the appliance leak though.
    Advice on E4 faults is if there is a flow meter in the tank, replace it, if not other models you can only remove water and test for leak, once you`ve established no leak, walk away, it may not leak ever again.
    But its a Baumatic, which I believe translates to its a pile of turd and you`ll probably be back within 6 months, for the rest of the life of the appliance, which won`t be too long, as its a Baumatic which means its a turd. 🙂
    #306196
    Just a Chinese dishwasher – inscrutable. And junk – I wouldn’t get too involved.
