I Need some advice on a baumatis BDF683 it keebs coming up with
E1, and that tells me its to do with the Water Inlet, I have taken the hose of the tap and cleaned out the filter but it still won’t
clear, I did have the dish washer on its side to check out the
motor and found it needs a new one, any help would be greatfull.
Mike
Check the filling speed through the air chamber as these can scale up and take just a few seconds too long to fill and time out (E1). This particular machine has the water meter / reed switch as part of the air break; could be at fault too. I’d look there first.
