Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Baumatic fan oven hot heating correctly
- This topic has 8 replies, 3 voices, and was last updated 20 years, 10 months ago by
londoncornish.
June 16, 2005 at 10:56 am #10146
londoncornish
ParticipantHi I have a Baumatic fan oven that does not heat up fully. If I turn it on, after about 30 mins it still has not reached the full temp. (If I turn the temp control back the light seems to go out around 150c)
Any ideas what the cause/solution is ?
Joolz
June 16, 2005 at 12:43 pm #138588Dave_Conway
ParticipantRe: Baumatic fan oven hot heatign correctly
Element possibly 😕
Model number please 😀
June 28, 2005 at 10:55 am #138589londoncornish
Model Number
BT 401 YEL
It seems to only be a problem when using the fan – when using the convector oven it seems to heat up to the correct temp OK !
June 28, 2005 at 1:38 pm #138590Dave_Conway
Yes, it will have different elements for the different functions, I think the fan element may have failed but you’d need this checked out by an engineer if you’re unsure of how to go about it.
Check repairs@ for one 😀
June 28, 2005 at 2:54 pm #138591londoncornish
Cheers Dave,
I will find a Baumatic engineer, as there isnt one listed on your list (unless they are known by another name!?)
June 28, 2005 at 3:50 pm #138592Dave_Conway
It’s mainly because Baumatic spares are notoriously difficult to source so the guys just don’t want to look at the stuff as a whole, but as this is a fan oven element (hopefully) quite often generic types will do the trick.
Pop up your postcode (1st part) and I’ll check some names for you.
June 28, 2005 at 5:56 pm #138593londoncornish
SE16
Cheers mate
June 28, 2005 at 8:38 pm #138594Dave_Conway
ParticipantRe: Baumatic fan oven hot heating correctly
Try these guys:
Sellens Service 01732 521500
If you could let them know whereyou got the number it would be appreciated 😀
A Cornishman living in London ?
Jellied Pasties 😯
I’m allowed to take the mick as I’m in Devon 😆
June 28, 2005 at 8:43 pm #138595Penguin45
Watch it……
Leedscornish(We have our pasties in Yorkshire Puds)
