one of the common things that can happen is the door lock moves into the closed position while the door is open. that means the door wont close the last half inch and the programme may no go
you can normally get a piece of old wire coat hanger . loop on one end to protect eyes and a turn the last quarter inch of the other end at 90 degrees. you can then hook this round the closed hook and pull it forward to the open position
