Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Baumatic OSF60OVEn – No power to oven and grill
- This topic has 11 replies, 6 voices, and was last updated 12 years ago by
bongomadness.
March 23, 2014 at 12:22 pm #80066
bongomadness
ParticipantHi there,
This morning I switched the oven on to find it wasn’t heating up. nor was the grill. The timer and clock display are however functioning.
I’ve check the timer, using the guide on this site, and can confirm that the timer is set to manual and still no power to oven and grill.
I’ve opened up the oven perhaps the only thing I can see which may be the potential culprit fault is the red terminal on the temperature selector is charred a little, see picture:
however, the selector does make that functional-sounding click if I turn it.
I cannot seem to see any internal fuses, well nothing obviously pops out to me,so any assistance would be appreciated.
Thanks,
GMarch 23, 2014 at 12:34 pm #411542Jackal
ParticipantRe: Baumatic OSF60OVEn – No power to oven and grill
You need to replace the thermostat and rewire the lead.
Isolate the unit fully before conducting the repair.
Jackal
March 23, 2014 at 12:39 pm #411543bongomadness
Thanks for the quick reply Jackal.
The until is well and truly isolated, plug taken off to get the thing out of the unit.
Is there any way to testing the thermostat?
cheers,
GMarch 23, 2014 at 3:20 pm #411544bongomadness
Hello,
After tinkering a bit today, I tested the temperature control dial, I simply checked the continuity between the live and neutral and it appears to function ok i.e. there is continuity over the terminals when on.
I tested the continuity of what I think are the thermal overload cutout (TOC) thermostats, see photo below. And I discovered that one of these devices has no continuity across it.
I assume the TOC is at fault. Can anyone advise whether these things can stop working of their own accord, or if they stop working they’ve been triggered by a secondary fault?
March 25, 2014 at 6:47 am #411545bongomadness
Update:
I’ve now ruled out the thermostat I mentioned above as faulty. After removing it and bypassing it I discovered this thermostat controls the cooling fan, since the fan started up straight away when I powered up the cooker. This is logical in hindsight.I think the problem is the timer circuit board, possible the relay or what ever provides the 6vdc power to the relays coil. It’s difficult to check these components since access to the relays terminals is restricted by the digit display, also it’s covered with some sort of film which seems to insulated the terminals and makes continuity checking a problem.
As a temporary solution, I’ve bypassed the timer circuit and the over/grill heats up normally.
Now to try and find a new timer circuit board. Does anyone know where would be best to obtain one of these, or, a reconditioned one?
Thanks.March 25, 2014 at 9:03 am #411546Martin
We have yet to learn if you have actually replaced the thermostat and lead as Jackal advised?
March 26, 2014 at 7:26 am #411547bongomadness
Hi Martin,
Not yet, I want to source the both components together if possible. Having said that, the Thermostat will be replaced as priority, the scorching is a certain sign of trouble.
July 18, 2014 at 4:43 pm #411548noon56
Hi have you had any luck fixing it the same happened to mine yesterday the oven is 14 months old
July 19, 2014 at 6:26 am #411549admin
KeymasterRe: Baumatic OSF60OVEn – No power to oven and grill
We can supply the parts if required
Bryan. Service@ffrservices.co.uk
July 21, 2014 at 12:50 pm #411550noon56
Hi what would be the cost of the parts
May 25, 2015 at 4:44 pm #411551greg10587
Hi There
Help needed please,my oven has suddenly stopped working, the programmer on the front has no response to any of the buttons being pushed, the clock is present at the front but what ever button i push it does absolute nothing,i have taken the back off and visually checked and there seems to be everything in its correct place and no burnt parts, does anyone have any advice please and if i need a part where to get it from,
Kind Regards
May 26, 2015 at 11:27 pm #411552admin
We can supply the parts if required. You need to test the appliance to fond out which parts.
Bryan
