Baumatic oven
  • #92921
    aguacaliente
    Baumatic BO788SS, (Gas) only bought it 6 weeks ago and just fitted it (secondhand) is the top oven only meant to stay alight with the door open as using as a grill, also the burner does not appear to ignite on the first burner hole from the jet so has the problem of not heating the thermo-couple, any ideas please. (Been in contact with Baumatic ! ? )
    #452594
    kaibart
    Re: Baumatic oven
    If this wasn’t fitted by a gas safe engineer I can’t give you any guidance, also if it’s 2nd hand you need the instructions for it which I would download
    #452595
    don
    Re: Baumatic oven
    aguacaliente wrote:Baumatic BO788SS, (Gas) only bought it 6 weeks ago and just fitted it (secondhand) is the top oven only meant to stay alight with the door open as using as a grill,
    According to Google the top cavity is grill only no oven mode. Have had a quick look for instructions which I am unable to find. If there is a little plunger switch along the top edge of the grill compartment then yes it is open door grilling. Shutting the grill door when in use will confirm this if the flame goes out.
    aguacaliente wrote:also the burner does not appear to ignite on the first burner hole from the jet so has the problem of not heating the thermo-couple, any ideas please. (Been in contact with Baumatic ! ? )
    Sadly forum rules do not allow us to advise on DIY gas repairs info here you could try our find an engineer search here for local one to you.
    Don
    #452596
    aguacaliente
    Re: Baumatic oven
    Sorry should have put my location as deepest Spain,NO gas safe people here,so why doesn’t the first burner hole not ignite ? (NO comeback)
    #452597
    aguacaliente
    Re: Baumatic oven
    Any ideas ?
