Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › baumatic single fan oven b152ss
- This topic has 10 replies, 2 voices, and was last updated 1 year, 10 months ago by
adv.
May 23, 2024 at 7:13 pm #102771
adv
Participanthi fokes hope you are all well , got a red scratcher here . customer said burning food and temp light doesnt go out . looked on connect ,obsolete . so went and fitted a hotpoint/whirpool one fitted fine .. , but when i turn knob to oven ,the oven starts heating up and temp light comes on without turning the temp knob to anything .. if i turn the temp on thermostat down i can hear it clicking . but does not turn the temp light off or stop oven heating to full blast :confused:weird .. do the baumatic thermostats work a different way ?i brains fried . or is it a faulty new stat ?or it something like a over heat stat or something ? tried the 2 wires on both side of the thermostat still the same ? help 🙁
May 23, 2024 at 7:18 pm #490386adv
Participantcustomer says original one never really made a clicking noise when turned it up or down :rolleyes: mmmm
May 23, 2024 at 8:15 pm #490387electrofix
Moderatorok try something
take one wire off the stat and see what happens as it should not heat. that will prove the circuit. you could do it with a multimeter to save turning it on
according to one of my sources it transposes to part no 49107216
connect have it for a mere £73 plus vat (ouch)
some stats close the contacts in the off postion to allow the grill to work again you cab check with a meter
ps have emailed you the wiring diagram as it will be easier to see than on here
May 23, 2024 at 8:21 pm #490388adv
Participanthi mate am not that great with wiring diagrams tbh .. the old stat is always showing continuiaty .. and it doesnt click at all when turn it .. but is that because its faulty ? what do you think it is mate ?no one else has been at it ,, he said
May 23, 2024 at 8:31 pm #490389adv
Participantif took one of wires of the thermostat it surely couldnt heat up ? that would be impossible not ?:rolleyes:
May 24, 2024 at 8:36 am #490390electrofix
Moderatoradv wrote:if took one of wires of the thermostat it surely couldnt heat up ? that would be impossible not ?:rolleyes:
that why i said to take off oner wire
if it stops heating then you know its just a stat problemDave
May 24, 2024 at 8:42 am #490391adv
ParticipantOk.all try that
May 29, 2024 at 3:28 pm #490392adv
Participantwell went back to this took wire off stat still heating up .took both wires off still heated up .. thought i was losing my mind .. :confused: took back off was just about to right it off . then noticed the double earth was on the neutral side of the element wtf ..:mad: customer said never been looked at before . luckily we both never got fried especially him been in for 15 years 😮
May 29, 2024 at 7:31 pm #490393electrofix
Moderatorwell that proves the age of the house wiring as any modern system would blow the RCD
May 30, 2024 at 1:14 pm #490394adv
Participanthe said it has got a modern rcd consumer unit :rolleyes: thanks for help again much appreciated ..;)
May 30, 2024 at 6:47 pm #490395electrofix
Moderatoradv wrote:he said it has got a modern rcd consumer unit :rolleyes: thanks for help again much appreciated ..;)
well it cant work
its supposed to trip at 30Ma to earth and your shoving about 8 amps
