baumatic thermistor
  • #67910
    dominicclegg
    Hi i have a baumatic bdw45.1 dishwasher and it has come up with error code E6. Having looked in the manual it says it is the thermistor at fault. could you please tell me where this is located and whether i can order the parts from here.
    finally i know what fault codes are like and can be a.bit random. is it likely to be the thermistor
    Thanks in advance
    #369014
    Re: baumatic thermistor
    Could be an open, short or a wiring issue.
    After that it can be more complex but the fault code is only a pointer in the right direction.
    dominicclegg
    dominicclegg wrote:Hi i have a baumatic bdw45.1 dishwasher and it has come up with error code E6. Having looked in the manual it says it is the thermistor at fault. could you please tell me where this is located and whether i can order the parts from here.
    Thanks in advance
    Hi does anyone know where the thermistor is located on this machine please so i can test it.
    #369016
    Here’s the lovely Chinese blow out, it’s item 1093.
    As you can see, it’s about as helpful as a chocolate fireguard. The stat is mounted underneath though and, if it’s like one I had to do a while back, it’s a total pain to get to it. You need to get the dishwasher out, strip off the sides, strip off the front panel to get access.
    The thermostat, if you need is, is here.
    dominicclegg
    sorry to be a pain but i cannot enlarge the image without distorting the numbers and cannot read the numbers as they are tiny. could you tell me which part 1093 is on the diagram please
    #369018
    The one on the top right corner.
    The full version isn’t much better. :rolls:
    dominicclegg
    Thanks for that
