Baumatic Washing machine – Won’t spin + burning smell
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Baumatic Washing machine – Won’t spin + burning smell
  • #35854
    Not_again
    My washing machine is giving me grief, the other day I was walking through the house and there was a bit of a burning smell which I tracked to the W/M. The cycle seemed to be going ok and there was no smoke or obvious heat so left it running as it had nearly finished. A few minutes later I checked back and all the lights were flashing and it had stopped mid cycle. It allowed me to drain the water out and open the door.
    Now, when I go to start a new cycle it fills with water as normal but when it start to do its first spin / rotate it does about half a turn, freaks out and all the lights flash. It does then allow the drain cycle to release the water and open the door.
    Any idea’s what the problem is/could be? The father in law seems to think its the water pump but as its draining / filling fine so I’m not convinced. The W/M is only about 14 months old (although it is a budget machine). It may also be worth mentioning that I have a dog and regularly have clothes / dog beds in the wash that are covered in her hair.
    Any advice would be gratefully received before I give to the old iron men!
    Cheers.
    #248413
    What model is it?
    Not_again
    Re: Baumatic Washing machine – Won’t spin + burning smell
    I think it is this one the BFW1000W
    #248415
    Okay, Baumatic can be anything badged as Baumatic so we really need the correct model number to help you.
    IF it is that machine then we need to now what lights are flashing as that’s an error code which, while it won’t tell you exactly what’s wrong, it may give you a clue on where to start looking. It does sound motor related though.
    The good news is that if that model number is correct then parts should be available pretty cheap although they may take a while to get if we can’t track some UK stock.
    However a budget machine like that I would not say is suitable for washing dog bedding in if it’s regular, pretty much no budget machine will be. 😉
    HTH
    Not_again
    Cheers for the info, just been reading through the manual myself. I’m pretty certain this is the model.
    All 3 of the lights are flashing, which, according to the manual means that the motor has failed (makes sense).
    Err 07
    The START/
    PAUSE light,
    PROGRAM
    READY light
    and PROGRAM
    END lights are
    blinking.
    The Motor has failed.
    Shut down your machine and
    unplug it. Turn off the water
    tap and call your nearest
    authorized service centre.
    Looks like I need a new motor? Any idea about 1)place to get one 2) cost and 3) ease of fitting?
    Thanks again.
    #248417
    It would be a special order that I can add to the shop easily for you if required and is roughly about £53 plus VAT and shipping from the info I have, but that could change dependent on current pricing as this info is about a year or so old.
    Easy to fit to us but probably not so easy for the inexperienced. 😉
    HTH
    WhirlpoolQueen
    Silly Question Did you register your warranty with them? I have just read this on Baumatic’s Site Instruction Book for your machine. – Could save you some money honey? – WQ
    Baumatic Ltd. Conditions of guarantee
    Dear Customer,
    Your new Baumatic appliance comes complete with a free 12 month guarantee covering both parts and
    labour costs resulting from defective materials or workmanship.
    Baumatic also gives you the opportunity to automatically extend the guarantee period for a further 12
    months at no extra cost, giving an initial guarantee period of 24 months. The extended guarantee period
    applies to England, Scotland, Wales and Northern Ireland only.
    To qualify for your full 24 months guarantee you must register your appliance within 28 days of purchase
    to be covered under this guarantee. This can be done online via: http://www.baumatic.co.uk or through returning
    the guarantee card which can be found in each new Baumatic appliance.
    * In addition, your appliance is covered by a 5 year parts warranty. Baumatic Ltd will provide free of
    charge the parts required to repair the appliance, only if they are fitted by a Baumatic engineer, for any
    defect that arises due to faulty materials or workmanship within a period of 5 years from the original
    purchase date.
    * An additional 1 to 3 year insurance scheme for labour is available should you wish to extend the
    warranty period.
    Should any person other than an authorised representative of Baumatic Ltd interfere with the appliance, the
    policy is negated and Baumatic Ltd will be under no further liability.
    The guarantee covers the appliance for normal domestic use only, unless otherwise stated.
    Any claims made under the terms of the guarantee must be supported by the original invoice/bill of sale
    issued at the time of purchase.
    This guarantee is transferable only with the written consent of Baumatic Ltd.
    If the appliance fails and is considered either not repairable or uneconomical to repair between 12 months
    (2 years if registered) and five years, a free of charge replacement will not be offered.
    The guarantee for any replacement will only be for the remainder of the guarantee on the original product
    purchased.
    The guarantee does not cover:
    – Sinks and taps
    – Failure to comply with the manufacturers instructions for use.
    – The replacement of cosmetic components of accessories
    – Accidental damage or wilful abuse.
    – Subsequent loss or damage owing to the failure of the appliance or electrical supply
    – Incorrect installation
    – Losses caused by Acts of God, civil war, failure to obtain spare parts, strikes or lockouts
    – Filters, fuses, light bulbs, external hoses, damage to bodywork, paintwork, plastic items, covers,
    baskets, trays, shelves, burner bases, burner caps, decals, corrosion, rubber seals.
    In the course of the work carried out it may be necessary to remove the appliance from it operating
    position. Whilst all reasonable care will be taken, Baumatic Ltd cannot accept responsibility for damage
    sustained to any property whatsoever in this process.
    This guarantee is in addition to and does not diminish your statutory or legal rights.
    Contacting Baumatic Ltd
    Sales Service Spares Technical/Advice
    TEL: 0118 933 6900 TEL: 0118 933 6911 TEL: 0118 933 6922 0118 933 6933
    FAX: 0118 931 0035 FAX: 0118 986 9124 FAX: 0118 933 6942 0118 933 6942
    For ROI (Republic of Ireland), please contact one of the numbers below:
    TEL: 01 – 6266798 FAX: 01 – 6266634
    Thanks you for buying Baumatic.
    * Applies to UK, Scotland, Wales & Northern Ireland only (Republic of Ireland has 1 year labour & 1 year parts warranty only)
    #248419
    hi
    You mean its lasted 14 month’s 😮 .
    As Monty python would say…”you lucky lucky {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}6&45^” Keep it to yourself else everyone else will want it.. 😈
    Bryan
    #248420
    Now, now, Bryan – it’s the MEGA6 you’ve got to beware of – China and all that.
