Baumatic WD602
  • #68294
    rocker
    customer tells me the machine runs for about 10 mins then a fault code FO2 flashes up..what does it relate to please.
    havent got fault code book on this, john
    #370480
    Jackal
    Baumatic WD602
    John hi
    We are main Baumatic agents and don’t recognise the model number.
    Baumatic don’t list a WD602 on the technical info site either.
    Can you check the make and model and come back to me.
    Regards
    Jackal
    #370481
    rocker
    Re: Baumatic WD602
    Thanks Jackal, I have just contacted him and he said it was purchased from comet as a westernhouse but was insured as a Baumatic (confusing or what )
    john
    #370482
    Jackal
    Baumatic WD602
    John
    That makes sense now you mention a Comet sale.
    Baumatic don’t actually make any product but buy it in from others. Comet bought a range in under the Homark name from Westinghouse.
    When Homark went belly up, Comet passed over to Baumatic some of these units for repair as they were the only ones at that time prepared and able to service them and subsequently marked some of the insurance products as a Baumatic product when it really wasn’t.
    Those machines are known to us at Baumatic under model BTWM5 or BTWM6.
    Fault Code F02 is insufficient drain within required time. Could be the drain pump or simply blocked.
    Hope the above helps.
    Regards
    Jackal
    #370483
    rocker
    Re: Baumatic WD602
    Jackal, you were spot on, blocked fluff filter. Thanks John
    #370484
    Jackal
    Baumatic WD602
    No problems glad you sorted it.
    Jackal
