BDW 13dishwasher e4 error code
had a look at this dishwasher found water in base,the leak was coming from the rear stat after nipping it up it still leaked so after closer inspection i found the stat holder had corroded.after replacing the stat holder put the machine on a cycle good news there was no leak from the stat, bad news the machine decided to overfill.tried it again a couple of times, the machine filled with differing amounts of water.pressure switch seemed to activate when blown through, and pressure switch pipe clear. does this machine have problems with the pressure switch or should i be looking elsewhere.
thanks for looking
Darren
