Bearing change on a CDA C1930
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bearing change on a CDA C1930
  • #72228
    zippo13
    Hi folks
    I’m new to the site so pleases be gentle!!
    I have an integrated CDA C1930 Washer/Dryer which has recently developed a screeching noise on the dryer cycle.
    The noise seems to be coming from the main bearing, I have just been reading on the site about some integrated machines being sealed units and it is sometimes not possible to change the bearings, could anyone tell me if this is the case with this particular model?? and if so what would you suggest??
    Thank you all for your time and look forward to hearing from you
    All the best Zippo ❓
    #383910
    Muv
    Re: Bearing change on a CDA C1930
    What make is the machine.?
    Muv
    Sorry just noticed its a CDA… Thought that was just part of the model number…im not familiar with this make, so will leave someone else answer you…
    zippo13
    Many thanks anyway Martin
    Zippo
