Bearing kit for electrolux wh2125
Home Forums Public Support Forums Spare Parts Help Bearing kit for electrolux wh2125
  • #34826
    omega
    Hi I need a bearing kit for electrolux wh2125.
    I have stripped the old bearings out and they are marked NSK 6207Z and NSK 6206Z.
    The bearing dimensions are
    6207 OD 72mm 35 mm bore 17mm wide
    6206 OD 62mm 30 mm bore 16mm wide
    The seal is marked 40.2 x 72/86 x 14/18.3
    Can you please advise what kit I need and suggest somewhere to obtain this from
    Thanks in advance
    Kevin
    #244129
    Re: Bearing kit for electrolux wh2125
    Pretty sure it’s this one:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=145
    Have a word with spares@ukwhitegoods.co.uk first to be certain.
    omega
    Thanks Penguin45.
    I will email them to confirm.
    Kevin
    #244131
    omega
    Spot on regarding bearing choice.
    Go to the top of the class.
    Kevin
