Bearing (motor) for Electrolux Z4646
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum Bearing (motor) for Electrolux Z4646
  • #53972
    colint
    The (front?) bearing on the motor axle has seized. Probably not worth the hassle of repairing, but is it possible to get a new bearing (or motor)?
    By ‘front’, I mean the bearing just underneath the aluminium fan. Looks like a pretty bog-standard bearing, to my unknowledgeable eyes 🙂
    Electrolux
    Model Z4646
    Type A1
    Thanks!
    Colin
    #317907
    Re: Bearing (motor) for Electrolux Z4646
    The bearing size (spec) is stamped on the outer bearing shield or on the outer part of the race. 108Z maybe or some similar number and available in most local bearing suppliers outlets. 😉
    #317908
    colint
    Martin wrote:The bearing size (spec) is stamped on the outer bearing shield or on the outer part of the race. 108Z maybe or some similar number and available in most local bearing suppliers outlets. 😉
    Great, thanks! I’ll have a look…
    #317909
    Thanks so much. This is very helpful. I did not know that the bearing just underneath the aluminium fan. Once I found this, I was able to get the repair fairly quick. I wish that they would make these easier to repair.
