Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bearing problem on Bosch WAQ28461NL Avantixx 7?
- This topic has 4 replies, 3 voices, and was last updated 11 years ago by
fixitall.
March 28, 2015 at 12:23 pm #84540
fixitall
ParticipantHi all,
I have a relatively new Bosch Avantixx 7 washing machine. Last couple of months I noticed a vibration during the spin cycle. It sounds like something is touching the housing, a kind of rattle.
I checked if anything obvious was wrong but I found nothing.
It also doesn sound like something got stuck inside from the wash, like the metal piece in a bra.
I want to make sure that it is not something I could have prevented or solved myself before calling in the troops (warranty) since that will result in cost for me. I then rather repair it myself.
So to come to my question, have a look at my movies (see links) and tell me what you think. Is this a typical sound of a bearing that is having issues?Movie: spin cycle with load: sound starts at around 1 minute
https://drive.google.com/file/d/0B52WmQ … sp=sharing
Movie: spin cycle without load: sound starts at a round 1.5 minute
https://drive.google.com/file/d/0B52WmQ … sp=sharingThanks in advance.
Peter
March 28, 2015 at 4:37 pm #425970simon26r
ParticipantRe: Bearing problem on Bosch WAQ28461NL Avantixx 7?
Sounds to me like the pulley is lose on the back, Went out to a job last week in weymouth and the lady told me she phoned another engineer first to be told over the phone it was the bearings. was just a lose beko pulley.
March 29, 2015 at 9:34 am #425971Martin
Hmmm? Sounds to me the drum unit needs replacing under guarantee. Faulty hub in tub moulding causing bearing ‘chatter’ at certain revs.
March 29, 2015 at 12:38 pm #425972fixitall
Hi Guys, thanks for your input. Sounds like I can call in the troops for a warranty job. Will let you know how that ends.
Peter
May 31, 2016 at 10:21 am #425973fixitall
Hi, saw that I did not update my post with the final solution so here it is:
Martin was right. It was something with the bearing moulding that caused chatter at certain revs. So the complete tub was replaced under warranty. Problem solved.
