bearing punch
  • #12311
    pmb
    hotpoint bearing extractor kit, can you buy the colliers separatly,
    we use them as a punch, and most of the kit isnt used,
    Or better still does anyone make a bearing punch with handle made to those sizes 💡
    #149031
    Re: bearing punch
    The ‘collets & springs’ of the Hotpoint kit are available separately, I don”t think the collars (which is what I think you meant) are though 🙁
    Any local engineering workshop (or Blacksmiths) should be able to make up whatever type of drift tool you require. Machined on a lathe to fit whatever size bearing you wish. Just show them a sample bearing and they should be able to cut one from various steel rod sizes. Some can also temper them for added strength. 8)
