Re: Bearing replacement – LG WM1290FHB
ok – have removed the back and pulley. rusty water has been leaking from the drum….looks like the bearings have forced a 5 mm hole through the plastic drum – its got shards of metal sticking out…doesn’t look healthy.
I am guessing these have 2 sets of bearings??? in which case the outer one looks intact but the inner one is well busted. I don’t plan on going any further…looks like a job for someone with the right tools…if its that damaged then not going to be easy to remove from the shaft or the drum…is it worth it?
