Bearing Replacement on Hotpoint WM31
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bearing Replacement on Hotpoint WM31
  • #29167
    jonah1
    Bearing on this seems to be welded to the shaft?
    Cant seem to get bearings out. Do i need a special tool or can i use
    my car bearing pullers?
    Any help appreciated?
    Also my rcd trips on spin cycle?
    #222160
    Simon46
    Re: Bearing Replacement on Hotpoint WM31
    Is the drum removed from machine?
    Regards
    Simon
    #222161
    aqualectric
    Before going any further with the bearings, you have to establish what is throwing the RCD. Most likely candidate is a shorting motor armature – you will need an electrical insulation test meter to confirm this. The armature is still available as a separate part. (only as pattern). Hotpoint themselves only supply complete motors now. They are not cheap.
    You now have to consider the viability of this job. How good is the rest of the machine? Is the drum shaft in excellent condition? How much has the machine been used in it’s life?
    True, the WM31’s build quality was of a much higher standard than that of a new Hotpoint. (AKA Indesit).
    BUT…. now you could need – bearings, drum shaft, motor armature and new brushes to effect a good long lasting repair. At the least you may be able to save the shaft: but it must be in perfect order – ie. no scratches, rust or score marks especially on the brass seal ferrule. If the bearings have broken up, replace the shaft. It is false economy no to.
    Complete bearings can be drifted out with a hammer and solid bar – if they are broken up, a special tool is available to remove the outer race. (priced at £100 + , 8O).
    Consider the above before buying ANY spares, or click ‘Repairs@’ on the homepage for an engineer in your area.
    Hope that helps!!!
    #222162
    jonah1
    Drum not removed. Pulley and locknut off.
    Does the bearing for this come in 3 bits.
    Problem with rcd tripping may have been due to loose plug and spin
    tripping rcd.
    #222163
    Washman
    The inner drum has to be removed to access the bearings and seal
    Mike
    #222164
    If the bearings are really bad then the heater may be damaged causing the RCD to trip. There are two bearings, front & rear, if you have more than two pieces then the machine may already be BER.
