Bearing water seal lubrication
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bearing water seal lubrication
Viewing 15 posts - 1 through 15 (of 21 total)
  • #60625
    pearce_jj
    Hi, after replacing bearings on Bosch washer (I posted some photos on another thread), a good few wash cycles down the line the drum still has a bit of a squeak as it starts or stops turning (no squeak other than immediately after it starts to turn or immediately before it comes to rest). Machine is quiet otherwise. I wiped over everything with an oily rag before fitment.
    Hence, wondering whether some additional lubrication is required on the rubber seal? I’m just a bit concerned about greasing it up as I wouldn’t be too popular if it ended up in the washing 🙁
    Here’s the seal in question – new one:
    And, the one it replaced:
    Many thanks in advance for any thoughts on this!
    #342976
    Dales-Electronic
    Re: Bearing water seal lubrication
    You should have lubricated the seal after the bearing change the detergent will disperse any excess – squeek is more likely to be the belt or the door gasket seal.
    #342977
    Could you explain why the seal is attached to the drum and not inserted firmly into the bearing spigot? 😕
    #342978
    pearce_jj
    Hi, thanks.
    The seal is on the drum only for the purpose of the photo.
    Is there any preference on type of grease to use?
    Many thanks indeed.
    #342979
    pearce_jj wrote:Is there any preference on type of grease to use?
    No just regular high melt point grease that’s all.
    #342980
    pearce_jj
    Many thanks.
    #342981
    pearce_jj
    I was wondering if Castrol Red Rubber Grease be the thing for this job… for use up to 110*C apparently:
    http://www.rgracing.co.uk/TDS/Grease/Re … Grease.pdf
    Many thanks!
    #342982
    Turbo
    I notice you have put the grease on the seal face when really it should have been placed in the seal lip as this is where it makes moving contact with the shaft. This could be the cause of the squeek. Or maybe the door seal rubber is catching the lip of the drum?
    You can buy special water resistant grease for bearing seals.
    Graham
    #342983
    pearce_jj
    Thanks for the reply. The white gunge in the second pic is washing powder gung actually, but thanks for the info.
    The grease choice is confusing…, the high temperature grease I can find is all lithium based so surely will ruin the seal?
    #342984
    Not at all, what will ruin the seal in your case is the already worn and somewhat rusty looking drum shaft collar the seal runs on! But, go for silicone grease if you like, that’ll do! 🙂
    #342985
    quickwash
    😆 , you guys!
    Thanks for putting a 🙂 on my face this morning 😉
    from a smiling quickwash :plug:
    PS – hi :martin: , and sorry pearce_jj, i just cant resist sometimes :rolls: , wish you good luck with your repair 😀
    #342986
    pearce_jj
    Thanks… I think! The collar and shaft cleaned up OK with an oily rag so hopefully there is life left in the beast yet 🙂
    Cheers
    #342987
    quickwash
    :waving: pearce_jj,
    Take no notice of me! A woman with a slightly warped sense of humour i’m afraid :rolls: 😉
    :tup: for your repair 😀
    best wishes
    quickwash :plug:
    #342988
    pearce_jj wrote:Thanks… I think! The collar and shaft cleaned up OK with an oily rag so hopefully there is life left in the beast yet 🙂
    I’m sure it will live to wash another day but ensure that the future of the machine is enhanced more by doing regular ‘Service Washes’. The detergent based detritus on the old seal was evidence enough to realise that service washes where not necessarily carried out that regularly perhaps? 😉
    #342989
    pearce_jj
    Thanks, we do run service washes but obviously not often enough.
    I just noticed our hosts have a grease that looks to be specific for the job….
    http://shop.ukwhitegoods.co.uk/Tools+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2 … rease.html
    Cheers!
