Bearings and seal info needed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bearings and seal info needed
  • #85168
    Madmac
    Have a Panasonic NA16 VX1 washer that needs bearings, cant seem to find any info on what’s used in this model.
    Anyone know the bearings and seal numbers ?
    Thanks,
    Eddie.
    #427929
    bazza500
    Re: Bearings and seal info needed
    It is almost impossible to replace the bearings on this machine as separating the inner drum from the rear drum just doesn’t happen. Under warranty the complete drum assembly was replaced. Now Panasonic just replace the whole appliance.
    #427930
    Madmac
    Thanks for the reply Bazza. Customer asked me to open it up anyway to see if I could ‘patch it up’ as she’ll leave it when she moves abroad later in year, she had no warranty left on it.
    Actually managed to have the inner drum sitting on the floor within a half hour as you can leave the rear half of the outer tub in situ.
    6207 and 6305 bearings I had to hand but weird seal I did not.
    Very corroded spider arms but the seal bush was clean.
    She agreed to a ‘no guarantees’ bodge so I put a smaller spring on the existing seal, which did make it grip the shaft ok 🙂 ,cleaned everything up, coated with grease, popped new bearings in and threw it back together 8)
    The whole thing took less than 2 hours including a cuppa, but there’s certainly a lot of stuff to move out of the way.
    Would much rather have done it properly if a bearing and spider kit was available but I certainly couldn’t find anyone selling one and drums are silly money for these machines.
    Anyway,was sounding good as new when I left 🙂
    Eddie.
