Bearings and shaft for Zanussi washer FL1085 Home › Forums › Public Support Forums › Spare Parts Help › Bearings and shaft for Zanussi washer FL1085 This topic has 2 replies, 2 voices, and was last updated 19 years, 6 months ago by CambridgeDave. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts September 23, 2006 at 2:49 pm #21085 CambridgeDaveParticipant Would anyone be good enough to confirm which replacement bearings and shaft I require given these machine details? Model: Zanussi FL1085 Type: P6296174 Product No.: 914780508 01 Serial No.: 813 00330 I suspect at least the bearings are available from this site. Many thanks in advance! — Dave September 23, 2006 at 5:06 pm #189427 Penguin45Participant Re: Bearings and shaft for Zanussi washer FL1085 Drum support – 50239964005 Bearing kit (2 bearings and oil seal) – ZN05105 You will also require the gasket between the tub halves, or the machine will weep water into the motor. Gasket – 1240159036 All components available in the shop@ facility. Regards, Penguin45. September 24, 2006 at 1:21 pm #189428 CambridgeDaveParticipant Re: Bearings and shaft for Zanussi washer FL1085 Thanks for the info, and thanks for reminding me about the gasket, too. — Dave Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
