Re: Bearings for a Bosch WOF2000 FF05
When it comes to the bearings then even the expert guys think twice before doing the job because;
1 It is costly(In UK it will cost you b/w £100 & £150)
2 It is a long job(atleast 2,3 hours)
3 It may be a 2 person job
According to the model you have a top loader washing machine I believe.
The bearing kits retail at around£40.It is not just opening the screws, one has to make sure that he does not damage the bearings(when putting) and also install it in such a way that it does not leak even after one puts everything back.
It will be very hard for a normal person to do such a big job or shall I say do successfull repair if you have not done it before.
Best to call a pro in your area.
Regards
