Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beeping Bosch
- This topic has 21 replies, 7 voices, and was last updated 14 years, 6 months ago by
Martin.
October 5, 2011 at 1:01 pm #65465
ParticipantWAE24468GB/17 having selected a programme wont start but just beeps twice. I discovered that the door interlock has blown a track on the module that supplies the interlock. So, I’ve ordered a new interlock and plan to solder a link wire over the damaged track in the hope the module isn’t bu$$ered. Fingers crossed……
Has anyone come across this fault before meanwhile?
October 5, 2011 at 4:08 pm #360647maltheviking
ParticipantRe: Beeping Bosch
Yes
Bit like the old Hotpoints, customers being a bit heavy handed slaming it shut. Check the catch on the door as well to see if it’s “lining up” with da hole in da lockOctober 26, 2011 at 10:04 am #360648Martin
Fascinating up-date on this job : –
After my visit my customer realised machine still under guarantee (22 months old) so I advised she call in BSH.
Ist BSH guy calls the following week, fits an Interlock, still doesn’t work. Plugs in his Laptop and diagnoses faulty Pressure S/w. Not got one on his van, goes away……
3 days later BSH guy No2 calls, fits Pressure s/w, still doesn’t cure fault. Locates blown track on PCB, goes away…..
A few days later BSH guy No2, returns, fits module, machine fires up, drum rotates he notices motor sparking, RCD goes, orders another new PCB and motor……
BSH guy No2 returns (yesterday) fits new Motor and new PCB, machine now working ….HURRAH!
1 # Interlock
1 # Pressure S/W
1 # Motor
2 # Control PCB’s
Customer phones me to tell me the full story, and they all lived happily ever after………..October 26, 2011 at 10:07 pm #360649leavemetogetonwithit
How long would an independent last with performance like that?
:stir:
Mike.October 26, 2011 at 10:34 pm #360650Lawrence
leavemetogetonwithit wrote:How long would an independent last with performance like that?
:stir:
Mike.The sad thing is Mike the independent wouldn’t be able to plug a laptop in …
October 27, 2011 at 7:54 am #360651maltheviking
Lawrence wrote:[The sad thing is Mike the independent wouldn’t be able to plug a laptop in …
Not that it did them much good when they did, after all it raised the pressure switch as faulty.
Because we dont have the laptop we would delve into the problem deeper.Now if you and I spotted a blown track on a PCB the alarm bells would ring that there may another fault that caused it, as Martin did
How did the machine “megger” out Martin on your visit? 😉October 27, 2011 at 8:06 am #360652Lawrence
ParticipantBeeping Bosch
Agreed ,it’s like when fault codes came out on the Servis quartz ,they still didn’t tell you the obvious basics they just narrowed it down a bit .
But with some of the diagnostics programs on machine it would helpOctober 27, 2011 at 8:13 am #360653Martin
maltheviking wrote:How did the machine “megger” out Martin on your visit? 😉
Yeah, now that’s a point? I see where you’re coming from here Mal. Now I come to reckon it up it did megger up fine at the time having removed all the panels, the motor plug and heater terminals…. :hmm:
When my customer said BSH No2 spotted sparking from the motor at the point where it blew the new module, now that is odd, it didnt show up on his megger either, clearly.
The original module’s tracks were blown in the immediate vacinity to the door interlock plug. The motor plug connector block is at the other end of the module and tracks around there, and the heater relay for that matter, were intact, triacs and sundry too! I had no reason to suspect anything other than the interlock causing the module to blow!
Speaking up regarding the quip about “Mike the Independent” (be that Mike the Bike or Mike 0800?) Had anyone reached the same diagnostic conclusion as I did at the time, we would have all been in the brown smelly stuff!
October 27, 2011 at 10:23 am #360654leavemetogetonwithit
Test post. Don’t seem to be able to post at mo. Or is Beeping Bosch locked? :hmm:
Mike.
Mod edit: Moved your post to the thread.Your post is fine Mike and this thread isn’t locked. It may just have been a temporary glitch at your end.
Don
October 27, 2011 at 12:57 pm #360655leavemetogetonwithit
leavemetogetonwithit wrote:Test post. Don’t seem to be able to post at mo. Or is Beeping Bosch locked? :hmm:
Mike.
Don
I’ve written something in reply to Martin’s post and every time I try to post it it comes up “ForbiddenYou don’t have permission to access /forumsphpbb3/posting.php on this server.” Yet I can post anything else anywhere I like. 😕 😕
October 27, 2011 at 1:20 pm #360656Martin
leavemetogetonwithit wrote:You don’t have permission to access /forumsphpbb3/posting.php on this server.” Yet I can post anything else anywhere I like. 😕 😕
I’ve heard this happening by a couple of guys on here also Mike, very odd goings on. 😕
Which post are you trying to answer as Don has lumped the Zanussi dryer thread onto the Beeping Bosch thread, so that may be the reason….?
Tatty thread syndrome?????? :clown:
October 27, 2011 at 1:26 pm #360657don
ModeratorRe: Beeping Bosch
Martin wrote:
Which post are you trying to answer as Don has lumped the Zanussi dryer thread onto the Beeping Bosch thread, so that may be the reason….?Tatty thread syndrome?????? :clown:
I forgot to change the post title 😳
Mike was trying to answer your post in this thread but was unable to post. However he could post into the Zanussi one and others.
Maybe one for Ken 😉
Don
October 27, 2011 at 1:27 pm #360658leavemetogetonwithit
Tell you what Martin, I’ll try and cut and paste my post into a pm to you, then you see if you can post it. 💡
Mike.October 27, 2011 at 1:32 pm #360659Martin
I await your every word with bated breath Mike…go for it. 8)
October 27, 2011 at 1:33 pm #360660leavemetogetonwithit
No, it got rejected when I tried to do that! :haier:
Never mind, I’ve copied it to a word document and will try again this evening.
Mike. -
