Beeping making me psychotic !
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beeping making me psychotic !
Viewing 15 posts - 1 through 15 (of 25 total)
  • #102071
    bekodonegood
    Hello Members,
    Newbie here. I did do a quick search but couldn’t find a specific answer to my problem. I have a Beko fridge freezer, model No. CFD63B, product code 7267546333, about 12 years old.
    A few weeks ago I had the fridge door open, and the door open alarm started beeping. I closed the door and the beeping continued. Switched the fridge off, left a few minutes, turned it on, still beeping. I noticed that the fan in the fridge wasn’t turning, so suspected the motor as it is linked to the door open switch (if the fan doesn’t spin the fridge thinks the door is open).
    Ordered a new motor giving all the appliance details, they sent the wrong one, it was too big for the housing. But as the connector was the same I thought I would plug it in to see if the beeping stopped….it didn’t.
    So now I’m wondering if it could be the control board at the back of the fridge. The appliance still works ok, but obviously the cold air isn’t being circulated around the fridge compartment. Some extra information. the appliance has a feature where you can put a bottle of liquid in the freezer to fast chill it and set an alarm by fiddling with the temp. control. If I set the alarm the beep stops, but after 30 mins (preset alarm time) the beeping starts again and continues as before.
    Does anyone have any ideas ? Thanks.
    #487427
    have you checked door switch operation
    bekodonegood
    Hi Dave, thanks for the reply. The door switch turns off the light when pressed, so that side of it seems ok. Is there some other way of checking it’s operation ?
    #487429
    well you can assume the switch works as long as the light turns off
    assume when you operate the sw by hand the light goes out but the fan does not start plus it still beeps
    bekodonegood
    Correct. As the fan wasn’t spinning (you can see it slowing down when the door is opened) that’s what made me suspect the fan motor. But assuming the new motor was working and didn’t stop the beeping, I’m looking elsewhere. The door seal seems undamaged and there is a vacuum when the door is opened. The compressor switches on and off, and there is no excessive freezing either in the fridge or freezer. There is some ice on the back wall of the fridge, but only in the form of frozen droplets, maybe because the top half is slightly warmer than usual ?
    #487431
    ok it could well be the door sw thats the problem
    it has double contacts so its poss the lamp one is ok but the other has failed
    bekodonegood
    Ok. Is there any of testing the switch once it is removed ?
    #487433
    yes you can test with a multi meter
    bekodonegood
    So I pulled the switch. There are 2 pins, one with 2 grey wires attached and the other with a single blue one. On examination there’s no damage (rust, scorching, etc), and the contacts open fully when the switch is operated. Sorry to be a total spanner, but how do I test with a multimeter, and what readings am I looking for ?
    #487435
    thats odd because the switch Beko say is the correct one has 3 connections
    bekodonegood
    There is a switch advertised on eBay,
    https://www.ebay.co.uk/itm/133566162611?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338766898&toolid=20006&customid=0c9d3a50c3f1b64013ee27593956078e&_trkparms=ispr{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3D1&amdata=enc{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3A1W2HNH1k2TBKgy5pSkf2QUQ52
    which is identical to mine, right down to the markings. TBH, I don’t have a lot of faith in these parts suppliers. The parts they recommend always seem to differ from the ones installed in my appliance, that’s why I prefer to pull the part and see what it looks like. The fan motor is a case in point, none of the ones on here look like mine !
    #487437
    well if Beko think your switch has 3 connection what else is wrong
    seems like the tech is wrong
    bekodonegood
    I don’t know about that, all I know is what the sites say vs what the part actually looks like. I bought the fridge new and it has never been repaired, so the parts should be stock. So, how do I go about testing the door switch ?
    #487439
    put the meter on a buzz setting so it buzzes when leads are together
    then put one lead on each terminal and operate the switch it should buzz in one position and not in the other
    all the tech shows a double pole switch which you have not got
    as a long shot have you got the serial no ?
